The piston will crack from the explosion.
kuzmich
Hey!
Two days ago I rode my husky with pleasure in St. Petersburg, beautiful view from the bridges, early morning, few cars, great time for a motorcycle.
At the next stop, at a traffic light, I noticed that the engine idle speed shows 1200-1250 rpm, the standard is 1650-1700 rpm.
The sound of the engine remained standard, no knocks, no peas.
After a couple of minutes, the engine stalled and would not start again.
I called a tow truck and took the motorcycle to the workshop.
I did all the necessary tests and checks, there is a spark on the candle, the gas pump buzzes, after I measured the compression, the value turned out to be very low 2.4 atm.
Disassembly was carried out, the camshaft cams were ok, the timing chain was ok, the gaps between the cams and the tokers were ok, after that I removed the head of the engine block.
The piston, despite the presence of a small carbon deposit, was intact, but had a crack.
A closer view
Back side view.
The cylinder is in good condition and not damaged.
To solve this problem, I need a new piston assembly, cylinder head gasket, cylinder gasket.
I have a question, what kind of pistons is there, besides the original one.
Is it possible to supply a piston from SWM.
Does the piston fit a 610 Husky.
Are there any other options?
Thanks in advance for your reply! :)
Gentlemens, I have a question.
The original piston kit number is 8000 H1024.
Husky's official representative offers a piston kit with the number 8000H6251 and writes that this is a replacement for the previous number.
The piston kit 8000H6251 also offers the official SWM for the RS650 motorcycle, in fact it is the previous Husky 630.
Do you think this 8000H6251 SWM piston kit and 8000 H1024 piston kit replacement for 8000H6251 are identical?
Are you adding fuel to the stock settings on your bike? Our bikes in the USA were delivered very lean which was could cause piston/head gasket/rod bearing problems. I'd hate to see your new piston damaged.
My carbed 610 endured much under my (ab)use, lasted into the teens, and never had a piston crack... hoping it is a one of, and you will not have a repeat... but it does look sketchy
Я заправил бак неизвестным бензином, в этом и есть причина.
Спасибо!
Сейчас все замечательно.:)
