Hi all. Here's my issue. Recently picked up a 2011 TE630. It has the JD Jetting tuner installed, but in my opinion, still runs like poo, especially at small throttle openings and on off throttle transitions. It bucks and stumbles when opening the throttle from steady state cruise at low rpm, and on off throttle transitions are very jerky. It still has the O2 sensor in the pipe, but I haven't been able to dig deep enough into the wiring to confirm it's still plugged in or has the power up plug/resistor installed. Otherwise stock. I'll check the JD Jetting settings tonight, but wanted to get some input with respect to tuning or suggested settings. Should I just do the PU plug if it's not already installed and reset to default JD jetting settings? Guess I have some digging to do?
