I replaced the head gasket on my 610 this winter. Rode it on a few short trips around the area and gasket seemed fine. i changed the oil the other day, took it out and when i stopped to take a look, there seemed to be some glistening on the gasket from right under the exhaust port next to the cam chain. There was also moisture on the gasket(wet to touch, no drops) around the cam chain chain side.
I pulled apart the top and retourqed but still very small amounts of moisture on gasket. There is no visible sign on the cam chain side or back of engine, just the glistening under the headers when run for a while. It seems strange too that the moisture would be on the cam chain side.
I also had the valves replaced when i had the head. When i had the carb off the other day i saw some carbon build up on back of valve and there was small amounts of oil on valves. From what ive read its most likely oil mist from intake. Im curious if I somehow have a head gasket leak thats going into the camchain area and pressurizing the system. causing what would signs of this be?
My plan is to ride the bike and keep an eye on coolant level and oil. I may try re torquing one more time
