TE511: power-up plug, JD tuner, Power Commander V or zip-ty
New511Guy
New to the site: Put this under "General" then thought it would be better here.
Got a '13 511. Bought the power-up plug from the dealer and put it in. Ordered an FMF slip on; haven't gotten it yet.
Question: What is the value of a JD or PCV above the power-up plug or having zip-ty (or someone else) reprogram the PCU. Do the JD and/or PCV just provide programmability or do they provide performance in-and-of themselves?
You basically need the zipty remap or PCV, or JD if you're going to put that FMF on. The bike is too lean from the factory without it.
Danny is right; you will need to do something regardless.
To answer your question, yes you will get performance gains along with tunability above power-up plug and the BMW #3 re-flash.
The BMW #3 re-flash is very good but not perfect like a PCV dyno tune would be (I am using Zip Ty re-flash with the TXC Akra, thanks Danny).
I'd imagine the FMF would have less restriction than the TXC Akra, and I'd say mine is running more on the lean vs. rich side with just the #3 map.
