TE511 MAP JUMPER PLUG
Mikepod
Here is the cheapest mod I ever saw! Instead of the official Husky plug ( #8000H5440). I just stuck a piece of solid wire in the socket and replaced with the original cap.
If you are wondering, the wire is from a standard 1/4W resistor lead.
A switch is better. Sometimes you have to switch it back to the A mode when it's acting up. Kind of like a TPS reset, but you don't have to unplug the the battery.
I wouldn't use a paper clip. I think they are made of steel as opposed to copper or tin. Copper or tin won't rust or corrode. Even though it's in a water tight housing I wouldn't do it.
Interesting, that will be map 1 and using the OX sensor. What if that sensor is removed. does it still work?
If you have map 3 installed, that would be Mode A of A&B. Works without the lamda sensor.
