Apri11
Hi, I had a few dramas of late with my particular ride (2013 TE511 - approx. 6,500km), biggest issue is the torque limiter gear bearing in the side cast casing letting go, unleashing quite a few deadly balls and metal fragments from hell into the crank case and destroying a few teeth in various gears. So after I had replaced what I thought needed to be replaced i.e. torque limiter gear, clutch basket, control gear Z=32, complete new side crankcase cover, new piston rings, gaskets etc. and reassembled the motor, the motor now has a a very evident ticking noise. The ticking noise varies upon throttle response, that is as rev's increase so does the frequency of the ticking noise. My only theory I can possibly come up with is that maybe the oil pump is not working as it should and the hydraulic cam chain tensioner is not seeing sufficient pressure maybe being the cause of the possible noise??? How would one actually test whether the oil pump is working as it should on these bikes as I can't seem to find anywhere in the workshop manual explaining how to do so? Any advice will be much appreciated.
Mods performed - ZipTy recirc kit
