TE511, am I missing a stock bracket? UpTite skid plate mounting..
klinquist
Bought this TE511 used, prev owner clearly had a skidplate on it that he/she removed since it didn't come with the factory one...
Bought the Up Tite skidplate... There are two bolt holes in the back that clearly line up, but not the front... The UpTite has the big "U" shape cutout where you can see the OEM bolts fitting through... but nowhere for them to attach... Nothing behind the center bolt hole on the Up-Tite...
Thoughts?
Thanks!
yes there is a bracket that bolts to the two bolt you are seeing that has a hole in center that would match your skid plate mount hole
FYI, There's a guy parting out a TE on eBay. Might be able to find what you need there too. Should be able to ask him to add a fixed price auction for just that part.
Good tip, thanks - but I already placed the order for the part I need. It was under $2 :).
