Apri11
My thoughts on the stock air filter setup are a little mixed, I just think a little more thought should have went into it's design. The relocation of the air box under the seat was a good idea, the filters seem a to keep a little more clean. My gripe is with the filter media setup and how it is mounted. I've been playing around today as I had some time and thought I'd share an idea. Give me your opinions good or bad.
1ea x Pod Filter
1ea x 50mm Type E Poly Camlock
1ea x Hose Clamp
The idea was to mod the 50mm Camlock coupling by cutting down to size a little, the pod filter will be secured on the end which was cut down and the other end will slip into the intake trumpet.
Filter end secured.
Slipped into the end of the intake trumpet and secured with hose clamp.
Insert the air box cover less the original filter and cage.
1ea x Pod Filter
1ea x Hose Clamp
Filter end secured.
