TE510 HELP
Fordy
Hi all. Im after some help and advice. I just bought a 2009 TE510 and the electric start is not working. When i hit the start button there is just a clicking noise and nothing happens (it just clicks once). I bought a new battery so that isnt the problem, but i cant think what it could be. Any help would be much appreciated. Thanks :)
Easiest thing to check is make sure it's not hung up on the compression stroke. Pull the manual compression release lever and press the starter button, it should turn over real fast, and just let go of the compression release lever while its the motor is turning and it should start up.
Next easiest thing to check is the quality of the grounds, at the battery and at the starter and at the frame. Take them apart and wire brush them or file them until shiny bare metal shows.
The starter button itself is harder to clean, I cleaned mine after I saw a multimeter check that showed some non-continuity. Take it apart slowly and see hows it goes back together as you work it.
