Te510 charging system
Andy clark
Anyone know about the charging system on these? When running it has the same volts at the battery as when it's not running? So I'm guessing the charging system is not working?
Thats not right. Check that your stator has ac output. If it does then prob your regulator/rectifier is no good.
yep. (around 12.6v or less, right?)
go simple first: check the wiring (& battery connections, regulator connections) for breaks, abrasions, connections, etc.
after this, you might need to take a hard look at the regulator itself or the stator/windings/magnets (and debris in them).
good luck.
