TE449 throttle body ground
Radar
I have had questions about the proper way to ground the throttle body. Here is a photo of how I did mine. As you can see I attached the small green wire from the TPS mounting screw to the sub-frame bolt on the right side of the engine.
Thanks Radar. Very helpful. I will now proceed with confidence.
-Jasov
P.S. What is the metallic duct tape on the gas tank doing for you?
-Jasov
That is foil backed self adhesive insulation. You have a red hot exhaust pipe next to a plastic fuel tank what could go wrong?
Could boiling gas next to the fuel pump cause "flame outs"?
Radar,
What is the earth wire for actually?
In the wiring diagram, the throttle motor & 2 TPS units have a ground wire. Is there a static signal in play there??
Radar,
The throttle motor and TPS units do have a ground ref but the throttle body it's self is insulated from ground. Air passing through the throttle body will build up a static charge. When the charge gets high enough it will arc through the weakest point. This can cause havoc in the ECU. When I grounded the throttle body on my bike it stopped acting like a pissed off teenager. Maybe because I an in the desert and we have dry air and more static electricity.
