Te449 - Newbie With Dead Crankshaft And Possible Dead Flywheel
beni911
Hello everybody,
my name is Ben, I´m coming from Austria and now after almost 20 years asphalt under my wheels I am on the way to my first dirt bike... I had the thought already, until then this year by chance a cheap TE 449 (2012, 3500km) fell into the hands... which needs some “love”.
As said the price brings unfortunately some work with it: the bike did not start with the electric starter, but could be bump-started, then it and ran… and rattled a lot (gearbox is ok). First we thought that there is a problem with the head (no compression), but after disassembling the complete engine it look likes the engine was driven “hot” as we say in German – the piston is scratched, also the cylinder a bit (but looks like can be serviced), and the connecting rod is damaged on both ends… The rest seems to be ok, also the head.
To be done: crankshaft with bearing, cylinder honing, piston,….
So first of all a crankshaft is needed… as I have already read a lot (Café Husky/ FB 449 owners group) the crankshaft is the weak spot of this bike in terms of repair or even getting an replacement for it… L
So my first question is: has anybody ever repaired a crankshaft? The work could be done by some friends of mine, but where to get spar e rod, bearings for it and the connecting bolt for the crank? Would save a lot of money… If not available, is the complete crankshaft available now?
Second question: removal of the f***g flywheel… The flywheel had something against being removed from the crank, and as in Dangermouse´s video (thanks man, I don´t know how many people benefit from what you have done and documented on your 449, thumbs up!) I had to head it three times to get it down, so the heat damaged the plastic rings between flywheel and magnets. Can I use the flywheel in this condition (see photo)? Would save a lot of money also…
So among others these two questions make the difference a good deal and crying myself into sleep every night… :D
Thanks in advance
Ben
So, crank is disassembled, looks like the conrod passed away... crank looks good. But thats no help, because no conrod is available as far as i know?+DSC_0668.JPG+DSC_0671.JPG
I am assuming that you tried the 449/511 facebook group too? I hate to say it, but they're more active.
Whoops- nvm. I re-read your post.
Keep us updated.
You can still get rods, just no crank. I'd check to see if you can source a local shop to rebuild the crank. We have a special mod we do to improve oil flow around the big end, but you'd have to ship it back and forth to the US.
Pro-X or Wossner should have the rod and piston too. Just put a Pro-x con-rod and Wossner piston in my ’06 510 SMR. They come with new bearings and con-rod pin.
