burnham
So I've got 200 miles on my bike now and I figured I'd change the oil and bolt on all the aftermarket parts I've been buying. So far I've put on,
Full FMF exhaust w/JD programmer
Fastway pegs
7602 radiator braces and guards
Cycra hand guards
14 t front sprocket
Mountian brake and clutch levers
Renthal bars
Scotts damper
Scotts shark fin
Pirelli MT 16 tires
Moose UHD tubes
Suspension sprung for my weight and valved for woods by FC. Shock shortened 4mm.
Uptite skid plate
I drained the radiators before I removed them to put the guards on, the coolant was brown when it came out. After it sat overnight in a clear contianer I could see there was a layer of brown fudge at the bottom and the rest of the coolant was the normal green color. I've run water through the system twice hoping to clean any crap out. I'll put new anti-freeze in next.
I changed the oil. I am a little concerned with the oil that came out of the bike because it smelled like gas. The oil looked very good, and the magnet on the drain plug didn't have a lot of metal on it, but there was almost 1.5 qts of gas smelling oil in the bike. I re-filled it with non-synthetic 10w40 and will change it again in a hundred miles. I looked for pinched vent lines on the fuel tank but didn't find anything. I haven't been beating the bike during break-in, but I'm not babying it either. I'm hoping the rings have seated and the next oil change will be a little more normal.
I saw the manual says to run 10w40, so I did. A lot of people here are running 10w60, is that something I should do? I wanted to stick with what the manual said to be safe. Thanks.
I'll put some pics of the bike up tomorrow.
Fastway pegs
Cycra hand guards
14 t front sprocket
Renthal bars
Scotts damper
Scotts shark fin
Pirelli MT 16 tires
Moose UHD tubes
Uptite skid plate
