huskydude59
Well have found a good use for the oil spewing out all over my motor. Pipe it down to the chain....perfect auto lube...
Just grab a piece of clear plastic tube. Fix to the air box vent, then run it down the frame tubes left side of engine. Caution on the header pipe.. pass tube underneath the plastic chain guard and fix it with zip ties... Done.... Stage two fix will be to take vent tube and 're route it to do the same thing... No more oil into the air box****************************************!
