TE449 2nd TPS adjustment question | PCV Install
Whittaker
When I installed the PCV on my bike I removed the throttle assembly that the 2nd TPS sensor is attached to using the two bolts highlighted in the attached photo. Does the 2nd TPS sensors have to be set now or can I just reattach the throttle assembly and do a normal TPS reset?
Well... I put the bike back together. Did a TPS reset. Loaded tinken's factory PCV map then enabled the autotune. The bike seems to be running fine so I don't think I need the TPS set by my local dealer.
You'll know if your power is limited beyond 4000 rpm.
I am guessing the only way to know for sure is by using the service tool? I just scheduled an appointment with my local dealer to be on the safe side. They're saying between 30-60 minutes to verify and adjust if needed.
Sounds like a good idea. I normally install the PCV without removing any of the efi components.
I accidently-on-purpose removed the same thing and didn't get it back on the right way and the bike idled really high.:eek: Reinstalled and got it right the 2nd time. Posted this thread and learned a couple of things.....namely, you don't want to mess with the TPS sensors :naughty:
http://www.cafehusky.com/threads/te-511-efi-adjustable-sensors.29357/
