Ok so I procured a nice set of Talon sprockets and DID x-ring chain to replace to OE equipment that is still on.
Had to blow-torch the rear sprocket nuts to soften the thread lock as the spokes get int the way of anything other than an open ender (already ruined one open ender prior)
Front sprocket nut came off ok with the pneumatic rattle gun.
BUT the rear axle just wont come out. I've managed to get it flush with the RHS swing arm as thats as far as i could go using a soft drift and a BFH.
No amount of pulling, jiggleing, twisting yelling or swearing will get this bitch to come out 1mm more.
I even busted out the slide hammer (a BIG one) even though i was reluctant to use it and that has zero effect either.
Any tips?
The workshop manual seems pretty useless, it simply says undo axle nut and remove axle.
I think whatever grease was in there has turned to glue.
Makes me worry about all the other moving parts in the suspension although everything seems tight and zero play.
Bike has about 1300km of mud use but i suspect the PO never touched it apart from oil, filters and cleaning.
Any tips?
