TE310 Something extra rotating with kickstarter... clutch? starter?
Mucci
Every once in a while I would hear something extra dragging / spinning when I tried to hot start my bike with the button. The issue got worse to the point where whatever it was wouldn't disengage last time I went riding. I could hear it dragging when trying to e-start so I instead tried the kickstarter. It had way more resistance and when I kicked through it sounded like it was maybe spinning the starter motor if that makes sense.
I'm trying to better understand this system but can't figure out how it would do that. If I understand correctly a worn out sprag gear spring would cause the opposite effect (not engaging).
The one way bearing is stuck in the flywheel. Its suppose to engage with the electric start and disengage when engine starts.
