te310 owners check your battery cable
josh310
I have a 2011 te310 and last weekend i went riding and on the way back to truck the bike started cutting out and died. I got to looking at it when i got home and when i pulled the seat off the bike died. When i pulled the seat off the battery would shake at idle and i found the positive cable had a hole rubbed in it from a little bracket that was unused. I fixed the cable and cut the bracket off and bike runs great so to you guys that own a te310 check that positive cable running off the battery and make sure it isn't rubbing on your sub frame.
I also had problems with my battery coming loose and ended up breaking the battery cable. I drilled holes and ran large zip-ties completely around the battery and then used Gorilla tape on top of that. You definitely want to tape the terminals to keep the battery from grounding on the frame if it comes loose.
