TE310 JD FI Tuner
JRE
Hi all,
Just bought a slightly used '12 TE310 that has the JDJetting Power Surge 6X fuel injection tuner installed along with the 12 TXC port injector. I don't seem to have the instructions for the JD Tuner and I have an FMF Q4 pipe to install which I'm thinking will require some tweaking of the tuner. If anyone has a online copy of the instructions (I didn't see any on the site) or can point me in the right direction as to what I might need to change, I would appreciate it.
I actually found the instructions although I'm not sure what would need to be adjusted for the new pipe.
It seems to me that the JD tuner is doing the same thing that the settings in iBeat do, i.e., richen or lean the low, mid, and high sections of the fuel map. A less restrictive pipe should flow more exhaust and allow the engine to breath deeper. I would think the air mass sensor would compensate some, but if you need more fuel, just increase the settings on the tuner (or get rid of it and just use iBeat).
