te310 front sprocket removal
bensl
i just tried to change my front sprocket tonight and i couldn't move the nut holding it on. i couldn't see any instructions in the manual so i thought i better check here in case im missing anything. is it just a case of flattening out the washer and (trying) to unscrew it? its not a reverse thread is it? i had a fair bit of weight on the socket and it didn't move at all.
any tips?
cheers
I had to use an impact gun to zip it off. A breaker bar with a 2x4 through the rear wheel to stop rotation and the bike in gear should work too. It's much easier to use a pnuematic impact gun to remove it for sure. Installing it with a torque wrench is recommended. And yes the only thing keeping it on there is the lock washer which it sounds like you figured out already. It has regular threads, not reversed. Good luck, you'll getrdone:thumbsup:
I hate those flat washers that are bent over-it's a pain flattening them out to get the sprocket off. They should do something like the KTM 'bowed' washer instead.
Honda had a nice two bolt setup and plate.
The splined shaft probably had a matching backer. In any regard was no big deal to r/r. I got under the bent washer with a chisel (no good as a fine tool anymore :rolleyes:), then large screwdriver.
finally got the f@#ker off! surprisingly a rattle gun wouldn't do it but finally broke it with a lot of heat and a looong breaker bar. (and a large mate on the brake pedal!)
any idea of the torque setting for it? i cannot seem to find any reference in the manual.
cheers
well after all that i have just discovered that the te310 sprocket is different to the one i bought. :( i thought they were the same across the range but obviously not.
bugger.
72.5 is the countershaft nut torque. Seemed like the one I removed needed close to 125-140 ft. lbs.. That is why you don't put it in gear. Something is going to give and better not be in the transmission.
