Burgo
Hi all,
I'm just wondering about Clutch adjustment on the 2013 TE310R.
It has the brembo hydraulic unit and I know you can adjust from the lever itself.
BUT, I'm wondering if there's any other adjustment points? Any way to make the same amount of lever movement create more clutch action? (Am I crazy even suggesting this?
Reason is I like where i've got the lever set at the moment, to limit lever Action and arm/hand pump, but when I put it in first gear with the lever pulled in tight, the rear wheel is definitely engaged.
Is there any accepted "normal" amount of drag on the clutch when in gear but clutch lever pulled all the way in? Or should it be none. Or, indeed does it just depend on how often you're willing to replace clutch plates
This is probably not doing nice things for the starter motor, which we all know is a bit flakey on this model.
If there's no other adjustment, I suppose I'll just have to play with it and push the lever further out?
Any advice is appreciated.
Cheers
Cheers
