TE310 (all x-lites) maintenance evolution discovery.
robertaccio
FYI, I was installing more CV4 insulation onto the bottom of my fuel tank. I was working first with fuel in the tank and decided that that was kinda a pita. So I drained the tank and immediately noticed lots of rattling inside the tank. The pump filter screen came out when I shook the tank around. This told me that the pump was unsecured. I pulled the 4 screws and was holding just the base, the pump assy was just hanging off the umbilicals (wire and hoses). The dual pump clips had popped out of the base retainer. I exercised the clip arms (bent them out carefully) and reassembled the pump and filter then reinstalled the assembly. I also covered the pump assembly cover with CV4 insulation to keep heat away from the pump. Good to go. So just give your tank a shake around to make sure nothing is unsecured inside your tank (FI models).
PS my TE310 is subject to more extreme activity/vibration/g forces than most.
