Te310 2011 Heat Sensor Issues
david creigh
just wont to add re heat sensors,i have approx 1800 klms on clock, 8 months old and ive had two recent fails. first related to heat sensor, second we thought was same,but computer check failed to show fault.i got bike back and pulled guards off to check electrics.found cut in lead off positive side of battery. which was at times touching the frame ,also the electrical component attached to with two fuses, had a fuse loose and a slightly corroded tab,fixed up and bike is running fine..
