TE250 with 12T Sprocket and 110/100-18 Rear
trackguy3
For those of you running a 12T front sprocket on your TE250, are you still using the stock Metzler rear tire? I’m planning to run a more dirt oriented 110/100-18, which is going to be smaller in diameter. Just wondering if the sprocket is going to be too much of a good thing.
I'm running a 12 tooth and a 110 100 18 rear, a non DOT full Offroad tire. That size rear is noticeably taller to me(compared to the 120 90 18 I was using). I like having the 12 tooth on the front because I run a lot of tight single track. If I didn't, I'd go back to the 13 t on the front and maybe try to find a 110 90 18 for a little lower profile.
