Gasp yet again, opening up the grimy air filter after a ride on a track with only a couple puddles... The airbox walls have small dried up dirt spots, possibly water that has been sucked through the air filter and 'carburated' into the airbox. I had the same thing last time after a slightly wet ride, too. The filter's inside looked clean, and the airbox doesn't have any particles big enough that they eye could see (the dirt was very small grit, basically dried clay). The air filter cover thingy was also completely muddy, implicating that it doesn't really do it's job well.
What's wrong? The filter is quite thick twin-air filter with coarse outside and almost fabric-like inside foam, i always oil it with bel ray oil, working it in small amounts well into the filter, and atleast smaller drops of water clearly get repelled by it, i also always oil the skirt real good. So might the problem be that the cover box gets filled with muddy water and the filter is powerless to stop it, this is supported by the filter being mostly grimy on the bottom part. The filter fastener seems to squeeze it in real good. Did i use too little oil?
I don't think the engine is yet ruined, still pulls like a mule and will not allow you to turn the throttle all the way, i am frightened that it will do something to the cylinder tho, it has been changed once because it had one small scratch that let oil past with pretty fast rate, perhaps it was caused by the very same problem.
Any ideas how to make this thing more water-proof?
