TE250 6 port vs 12 port injector
out_riding
Does anyone know whether the fuel flow is the same for the 6 port vs the 12 port injector? I know that Husqvarna only sells it as a kit with the ecu, but if the flow were the same, then you should be able to use the 12 port injector with the stock ecu. Does anyone know much about the Kawasaki injector? 49033-0011
I am using the 12 port injector with the stock ECU. It may run a tad richer now with a tad more punch. But, its very slight and it could just be me telling myself it has more punch to justify the purchase. It certainly wasn't a miracle cure for anything. I bought the combo from Halls, but the bike would simply not run with the new ECU regardless of the amount of iBeat or TPS tinkering. Halls nicely took the ECU back, but I kept the injector since it was used.
I am using the 12 port injector with a stock ecu also. I used ibeat to lean the co1 and co2 settings just a little and it works great.
So I pulled my injector out to see why it's not getting any fuel and my injector is a 4 port. The tip had some slimy film over the ports. I am hoping that this thing will run with the 12 port injector.
