TE vs TC suspension
DALE44
Hey guys,
Ive noticed in my manual (08 te450) that the te and tc have different suspension (is the tc a dual cartridge?) and was wondering whether it is much better? and whether the suspension could be swapped?
On a similar note, is there much else that can be switched?
Thanks in Advance
TC and TXC had different and much better forks than the TE's. They are interchangeable, I have 08 TXC forks on my 08 TE. Almost everything is interchangeable on those bikes.
Don't the TC/TXC have Ohlins shocks? Much better than the Sachs on the TE's. The most performance gain would come from the rear shock than the forks. How are the forks different btw? Thought they were both 50MM Zokes?
08 TC,TXC,TE have the exact same Sachs shock. They all have 50mm Marzocchi "Zokes" forks but the TC and TXC have different internals. The TE forks are cartridge and the TC,TXC are twin chamber.
sounds like a win then, ive had both cartridge and dual chambers, and the dual chambers are so much nicer. The reason i ask is because i have the opportunity to buy a blown tc250 2010 model. Will this have the superior ohlins shock? and since i would have the whole bike, i cant see any fitment issues as the triple clamps and all!
2010 TC250 has 48mm Kayaba sealed-cartridge forks. If they fit on an 08 frame you will need the 2010 triple clamps and bearings.
J-train, if you wanted a Ohlins shock on your 07 TE510. You could get one from a 06,07 TC, and it would fit your 07 TE
