teuchter
I installed my moto minder hour meter a while back and wanted to share how I did it - hard wire method.
First I disconnected the battery earth, installed the hour meter at the back of the airbox under the seat and removed the plug for the fuel pump relay located located on the left hand side of the bike behind the radiator fan.
I then removed the blue w/ green stripe wire (not to be confused with green w/ blue stripe wire ha ha) using a small zip tie tip.
I then soldered the red wire from the moto minder to the blue/green wire (fuel pump power supply 12v), attached the black motomonder wire to the battery -ve terminal and put it all back together.
Works great.
Works great.
