Cosmokenney
I've got a '13 TE 511. Trying to get the brake pedal as low as possible. But but it's causing brake drag if I move the eccentric cam so it's as [thick] as possible, thus moving the pedal down. I've loosened the jamb nut (there's plenty of thread visible above the nut) and cannot figure out how to get the back of the pedal to slide further up the plunger.
All the workshop manual says is:
Before staring the braking action, rear brake pedal shall have a free play (B) of
5 mm (0.2 in). Should this not happen, operate as follows:
- Loosen the nut (3);
- Operate the master cylinder linkage (4) to increase or decrease free play;
- Tighten the nut (3) at the end of the operation.
"Operate the master cylinder linkage"
What the heck does that mean?
All I can think of is that they expect you to press on the lever a few times with the nut loose. But that doesn't do anything.
Suggestions?
Suggestions?
