TE 630 Starting issues
motomatt72
I have a 2011 TE 630. I dont have much time to ride. Bike sat for 2 weeks. Went
to start it, turns over, but wont start. Think it could be a fuse. Battery is good.
What else should I look for? Thanks
Can´t remember whether you can turn the engine over without it starting when the "kill" switch is on (very easy to forget ... and then the battery dies).
But I had the same prob on the Autobahn and found that my spare tool sachet had rubbed through the very thin red wire on the battery. Could turn the engine over ... but no ignition.Easy to mend in seconds.
Battery not strong ENOUGH probally.. it can easily read enough and spin it without QUITE getting enough tyrnover speed to truely start it.. thats the "kicker" for a kicker mod on these bikes.. ;)
No the engine doesn't crank with the kill switch on. Easy sign for this is no neutral light. I very seldom try to start my bike in gear so always look for the neutral light first.
_
The battery is fully charged. I noticed however, when I turn the kill switch on, I don here the pump/FI system kick on. It just makes
a clicking noise when I turn the kill switch on. I have only 200 miles on bike. I love it, but dont have time to ride.Im looking to sell
it. Want $5400 for it. I will get it fixed before I sell it. Thank you for the responses so far
Theres only a few fuses.. replace them all if they are oem.. I cant tell you how many "fully charged" batteries werent able to turn a 610/630 over.. after fuses and checking connections you should really try another battery.
