TE 630 Stains on Gas Tank??
Hokeewaa
I have stains near the gas filler opening that look like spots where gas dripped onto the tank. Various solvents have not removed them. Using gas to darken the area where the stains are to hide them did not work.
Does anyone else have these stains? Any ideas?
Thanks.
303 Aerospace protectant. It won't remove them but will probably hide them. I have not had that issue either, but all of the matt-black plastic really looks great with an application of this stuff.
Before and after...
It sounds like gas additive stains. At the risk of melting the plastic, you could try acetone or MEK, possibly even laquer thinner. Or just WD40 first. Maybe whatever is creating the stain will lift enough to hide it. Seriously, try 303. If you use any of these aggressive chemicals you'd want to re-protect it anyway. WD40 is basically kerosene and pretty mild.
I'm guessing the tank is polyethelene. I'm not always sure which chemicals melt which plastics. It's obviously tough stuff though.
No guarantees! Don't come back and say you melted the finish off your plastics. :busted:
BTW, I would also try SimpleGreen with a nylon brush, even a tooth brush. Scrub it good and rinse. Treat with 303.
One thing I've found for the side covers and tank shrouds is Gel Gloss. That stuff they sell for showers and boats. TR3 Resin Glaze also works really well for cleaning and polishing plastic. Strap lashing marks and trouser marks buff right out.
Novus is another good plastic polish, just don't use the most aggressive polishing grit - No1 or 2.
