TE 630 key
LC4nicater
I have a 2011 TE 630 I seam to have lost my only key during my move last year.
I’ve tried calling the factory but, no help. Being that this is a one year only unicorn bike, am I screwed ?
Any help is greatly appreciated. I’m in Seattle.
Frustrating, but I doubt you’re screwed. It’s a common ignition switch, used on other bikes as well- so at the outside you could just get a new ignition and key set. First I’d try calling a bigger Husky parts supplier (Hall’s) to see if they have a blank, then see if a locksmith can make it work from there (dunno- never been in that spot.)
Also do a search of “key blank” on this forum and you’ll see what others have done.
Good luck- let us know what you learn.
The blank is a common ilco X270 TMC1. My locksmith had them in stock for $2. As for re-keying, I suspect a good smith could do it, especially if you pull out the barrel first and take it to them.
