TE 610 Rear Wheel
Put you back into it;) I don't carry a torque wrench on the trail and I don't think I've every over done it and I've never had a wheel come off either. I'll check the manual tomorrow and let you know. If you use the short wrench in the tool kit it would be hard to over do it
Drive chain adjustment
Carry out the cleaning operations as described in the “Periodical maintenance
card”. Check the chain tension adjusting and lubricate it, if necessary.
The chain is adjusted correctly when the motorcycle is in vertical position and
unloaded, as shown on figure. If not, adjust the chain as follows:
- loosen the nut (1) of the wheel axle;
- loosen the nuts (2) on both sides of the chain-adjusters then operate the
adjusting screws (3) till the correct tension is restored (make sure that both
the chain streighteners are aligned on the same notch);
- tighten the nuts (2) (22,5 Nm/ 2,3 Kgm/ 16.6 lb-ft);
- tighten nut (1) of the wheel axle (142 Nm/ 14,5 Kgm/ 104.8 lb-ft);
- check again the chain tension.
From 2002-2007 manual
Check chain slack 12mm 0.47in from center of lower chain to swing arm.
