TE 511 Flywheel Weight
Cosmokenney
What do you all think about putting a flywheel weight on a 511? That is if I can even find one. I really don't use the bike on the road that much at all. But I feel like my lack of skills would benefit from the added ability to tractor it in the technical stuff.
I think my WR125 could use one. i have never thought when riding the 511, at least not after it was brought
To run like it does now. I can run it a gear higher and it easily pulls all I can handle in the tight stuff, out in
The open, keep it a gear lower and use the great mid/top to drive out hard.
Not enough room to install, no plans on making one, does not need one. Porting the head seriously increases the low end torque on this engine.
If you're skills aren't that high, I wouldn't think adding a bunch of power to the bottom end would be a good idea. Once my PCV was dialed in my bike would tractor around like nothing I've ever ridden. If you're in Granite Bay, we're not too far away. I could make a trip out there sometime and we can compare settings and mods.
I'm starting to realize this was a fueling issue. I've gotten 15 minutes in since installing a JD Tuner and setting the "fuel pump" feature kinda on the high end. I also put the low rpm setting up a little.
It seems to have gotten rid of a lot of the bogging. In the 15 minutes I spent in the front yard "testing" it, the front wheel was off the ground more than it was on. That never happened before.
If you want to come out this way, PM me. A couple of our riding areas are opening up here pretty soon. I'd be more than happy to show you around some of our sweet single track. There's also a few group rides coming up that I plan to do.
Once the oil recirculation issue is squared away, the only other real issue with this motorcycle is fuel.
The PCV can establish improvements where the it is just not possible for the JD. Because the JD gives a generalized increase/decrease of fuel to zones, and lacks the functionality to be precise, in many cases you will be solving a starving issue while creating a surplus one.
I can HIGHLY recommend the G2 Throttle Cam as opposed to holding the motor back. I cannot imagine the 511 being much different, but I have never felt my 449 lacks any bottom end - in fact each time I ride it I find myself trusting to let it lug deeper and deeper into the stroke. I think my old 525 RFS was simply beautiful in its capacity to lug well into the auto decompressor - but I am trusting my TE in the same manner. Now that my flameouts are gone, I am not scared of letting an idle bail me out of rocky climbs.
I can say that the G2 adds a whole new scope of throttle control. G2 with EFI adds a whole new level of precise throttle control.
BTW, one other "hillbilly" solution to more tractor on the rocks is swap out a high tech sprocket for solid steel and a big meaty tire with a UHD tube. All that weight on the rear wheel can add a ton of low speed stability without making the motor struggle.
I like this. I'm still trying to wear out the stock Michelins. I've already geared it down. When the renthal sprocket is gone I'll probably go steel.
My stock Michelins didn't wear down, the knobs just chipped off the case, I was VERY happy to see them go :)
Absolute worst set of dirt tires I have ever used...hopefully Husky was obligated to them contractually. If someone actually tested those and said "Yeah, those work well..." I would be shocked. If so, they need to be removed from motor sports for life!
I couldn't find a single thing the Michelin's did right. I thought that pavement was one area they were tolerable until my knobs started just flying off. Sand, rocks, mud, hardpack, they were perfectly equal in sucking everywhere. Consistency they have down pat!
I'm running them at 8 or 9 lbs. They are okay under most situations. However any kind of rock or root step up and they just spin and spin and spin. And at 8 lbs I'm feeling the front rim a lot. It's just a matter of time till I pinch flat.
The 216 AA fat tire is the best we have found for the front. It sticks 3 times better than a MX51 motocross, doesn't wash out and it's DOT legal.
Is that the GT? Do you sell them? What's a good rear to pair it with? I was going to run a trials in the rear, but I've seen some reports that they aren't as amazing on the bigger bikes as they are on 250s and smaller.
I have a trials on my 449 and absolutely love it. I am just running a quality heavy rubber tube at around 7-8 psi. I have tried all of the tires and keep coming back to the MT43 - it does everything exceptionally well.
Trials tire + CTS = whole new style of riding
What's your font tire?
Ive been on IRC's for the last several years and have been very pleased. In a prefect world, I would run an S12 (my favorite front by far) but our terrain in the Ozarks is just too rough on them. The VE35 is one of the best do-all fronts I have found and they hold up exceptionally well. I put 700 miles on my TE last year and did it all on one set of tires. I will do considerably more this year, but will get by with one change (MT43 rear and VE35 front).
I dont care about the DOT thing - we dont have inspections or anything.
