TE 511 Clutch Problem - Help.....
tjb45
Hi all, just got back from a failed ride on my TE 511, 2013.
At one time during the ride, I when to move off in first gear and stalled the bike, it felt a little like it was in top gear or the rear brake was stuck on, releasing the clutch I could feel it load up but not move.. I rocked the bike and let the clutch out again and everything felt fine again.
A couple of other times it felt as if the rear brake was dragging a little, but not enough to be worried about.
After stopping again several K's down the road, I when to move off in first gear and the rear wheel was locked, same in second and third, releasing the clutch slowly it was just loading up the engine.
After rocking the bike back and forward in gear with the clutch in I could feel what was like a set of gear not meshing correctly and ticking noise. In natural everything feels fine.
I took this short video after I trailered it home, this is with the bike in second and the clutch full in.. The noise seems to be coming from the clutch area, sometimes it completely locks the rear when trying to push forward, if this happens I can roll it backwards a little then forward to unlock it...
Any help on what the problem might be would be greatly appreciated.
once you got it open , remove the pressure plate and check the big nut which holds the Clutch on the Crankshaft ...
Let us know how you go.
All those bolt heads look like they have been rounded off, or at least abused in some way...
Husky might have been using the imperial sockets for day when they put my bike together...
Anyway, Glad there wasn't any damage, but concerned what else might be loose.....
Definitely look like someone has been in there on those 10 outer bolts. Manual has torque settings and recommended loctite (they call it "encapsulated" something or another if I recall). Also I remember having to go around several times (in a star pattern) to torque those up as the initial bolts will need to be tightened further as the plate gets settled.
