TE 510 Starting Problems
Andrew LeRoy
Hi guys,
I just bought a 2007 TE 510 and it wont turn over. What is the starting procedure for this bike? Does the clutch need to be pulled in and the motor in nuetral?
It did turn over when I first got it but I replaced the clutch lever and it does not respond to the starter button.
Thanks for any help,
Andrew
check you have connected the micro switch on the lever , the clutch has to be engaged to start, thats if you have the electric
start model
