TE 510 shock oil
Hi, can someone help with the amount of oil and gas pressure for the rear Sachs shock on a 2005 TE 510 thanks
10-12bar sae2.5 shock oil , should take aprox 350 /400ml , you will have to fill it and bleed out air, i usually waste a little oil bleeding it
10-12bar 2.5w shock oil , should take aprox 350 /400ml , you will have to fill it and bleed out air, i usually waste a little oil bleeding it
OK thanks Dave,i'm rebuilding a 2005 model for a mate ,I have a 09 model myself and have done that before with no problems but this one has air in it, and i'm having trouble getting it out.Started to think my be it had more oil volume than the 09 model.
There must be something wrong with the compression adjuster as from hard to soft makes no difference, ( this is why we pulled it a part in the first place )
Any ideas ?
Thanks Graham
Any ideas ?
Thanks Graham
I have only done a couple of shocks for myself so no expert , I filled the shock [while rebuilding] worked it afew times while bleedind out {and fillingwith oil} the top compression hole . on my final bleed i over filled the shock {nitregon reservoir} , as i refitted the top compression adjuster i slowly pushed back nitregon reservoir piston to it correct position {2/3of the way in }
[the final bled was done with the shock at 45degree ,the compression adjuster at hightest point]
on the bottom left corner shock pdf http://docs.wavenetworks.us/manuals/
