TE 450 has no spark..
jjr0513
My 09 TE 450 won't start.. I checked the spark plug and tere is no spark
.. I have replaced the coil, lead and spark plug but it still wont start!! What should I check next??
Mine (2010 TE 450) is in the same situation. I'm grateful for any idea because I'm begining to fall in desesperation....
Bikes turn over with the starter button and the pump is priming- but no spark?
- changed/checked spark plug, cap and wire, and coil....
> I'd then inspect the
stator and pulser coil (tells ecu when to spark and fuel)/sometimes can "collect" metal shavings and loose signal- cleaning may help.
manual has tests for the stator
