TE 450 cracked clutch case
Andrew B
I have had a look around the Net to see if this is a common issue or not because recently I cracked the Clutch case near the kick starter after it backfired.
The crack was caused when the tab on the sliding gear sheared off.
All in all it is and expensive repair (AUD $ 450) from a part that looks a little under engineered.
It's a common consequence to an improper starting procedure. They're very sensitive to having any throttle applied while kicking. Make sure you also check the crankcase half where the kickstart gear is - mine broke there also.
