TE 449 or 511? Is there really much difference?
reaganbart
When I bought my 2011 TE 449 I was tossing up whether to by the 449 or the 511.
But is there really that much difference? I find the 449 to be great around town, and plenty of power and versatility out bush. Is there much more power with the 511?
Having ridden both back to back the 511 has slightly more bottom and mid and the 449 revs slightly easier. Noticeable but not huge.
Maybe your electronics are different than the US - but here in the US, folks seem to have less issues getting the 449's dialed in. Seems odd to me as the 511 is actually a 476 or something right???
A few folks here that own both 449s and 511s have commented that the 449 is way easier to sort the bugs out. I think we are beyond anecdotal evidence on that topic as it comes up frequently.
I have both, 2013's. 449 revs faster and higher, 511 torquier revs a little slower and not as much on the top end. Both great bikes, 449 needed no fiddling after fmf map 3 and smog junk removed. 511 was a bit more finicky, had to adjust brass screw to match 449, tps reset and run the quiet core in fmf for more back pressure. image.jpg
I have both, 2013's. 449 revs faster and higher, 511 torquier revs a little slower and not as much on the top end. Both great bikes, 449 needed no fiddling after fmf map 3 and smog junk removed. 511 was a bit more finicky, had to adjust brass screw to match 449, tps reset and run the quiet core in fmf for more back pressure. View attachment 40485
Capitalist!! :D
Nice bikes dude.
Thanks husky brother...I keep waiting for them to start to run crappy so I can try the BF removal, or have to tinker with them but so far so good. 449 has 1600 miles and 511 1100 miles
Ha ha.
Why wait?:)
Do one & it will become your favorite overnight....
I know I know we will see they're getting ready for oil changes again so maybe this weekend. Once I get the lower air box off there's the velocity stack, I assume that just pulls off then pull the tube off the tps and I should see the BF correct? 2 screws remove plate and replace air box parts.
You don't have to do the mod if you are happy, just teasing, but I think you'll be surprised by the change.
Once the lower airbox is off & the air-boot clamp is undone, the boot squeezes in at the sides where it goes into the airbox to pull forward into the box.
This MUST be 100% sealed when reinstalling, there's a lip either side of the plastic when seated correctly. It is fiddly, but do-able.
With the fwb motor & shaft, try not to force it around any more than needed to access the screw heads, motors like these don't like external pressure.
It may run fine, but you may also need some small fueling changes. Especially with the pipes you have there.
Not sure if you have a piggyback to tune with, but i was able to add enough extra fuel for mine by moving my tps sensor slightly so it runs on a different richer part of the maps.
Small movements are key, too far & it won't run in the range of idle voltages, I adjusted mine idling & warmed up.
Oh trust me I know I don't have to do it...lol...but more power is never a bad thing. I'm not running any piggyback programmers and that's why I haven't played with it yet. As they sit now they run great and because I have 2 bikes the cost of programmers double. I, like you didn't want to spend a bunch of money on programmers etc....for some reason my bikes don't push any oil in the air box either and I run 1150 cc of oil in them. It's funny cause after reading a lot of posts on CF I'm either lucky or they will both blow up 100 miles apart.
Same here on the oil. I've always run 1150cc and never had a problem.
