te-449...flame out king
marshwater
never had a problem with flame outs on the te449 before. i was running jd tuner, race map II and stock can. switched to the fmf slip on and now she will hardly run. about 25 flame outs on a 2 hour ride. not fun. any suggestions
Change your JD settings to go a bit richer, TPS reset, and make sure your idle is at least 2000 RPM. If that doesn't work, map 3
The instruction sheet for the JD has suggested setup for running the FMF. Start there if your haven't already.
What RPM is your idle? Try 1/8 to 1/4 turn on your idle screw and see how that feels. As soon as I got my idle 100 or so RPM over what felt right they totally vanished.
I did the TPS Calibration. installed FMF Powercore 4 . Got map 3 on it and happy with it. Had maybe 2-3 Flameouts in a 5 hr ride. And ist starts awesome now , even stalled in Hot conditions. TE511
No one has mentioned this, so I'll chime in since I've got the same bike/setup. Do you have the quiet insert for the FMF? I ran my bike without the insert and flameouts happened regularly. Added the insert and the problem went away entirely. I lug the engine all the time and can blip the throttle at low RPM to lift the front with no problems. I've got a 2011 model, so map 3 didn't work for me. Best of luck.
Map 3 is the cheapest solution to flame-outs. The PowerCommander 5 is the real solution to the 449/511. Not only for flame outs, but for power and the ability to switch maps on the fly. For me, fuel is a huge limiting factor and swapping to a mpg map on the fly greatly increases my range.
