TE 449 - clicking engine noise on acceleration
SD449
I'm hearing a clicking or rattle from the engine upon acceleration. This is a different noise than when you accelerate in too high of a gear. Has anyone else had this? There is nothing loose outside the engine, I looked around. Thanks.
I agree with AZuwere.
Sure sounds like detonation.
I hope you are not running standard octane fuel.
Must run 95 or higher, preferably 98.
SAM511
You may have checked this but youve not mentioned the chain is correctly adjusted?
Hi Spud
When you check the chain tension do you do it with the bike on a pit stand or with both wheels on the ground. the play they state in the handbook seems very tight.
please advise
twm
The 511 and 449 are unique because of the coaxial suspension linkage. My 449 has about 15mm up and down movement just in front of the chain guard. Also, whilst your checking the chain have a look at the chain guide. On my bike the rear sprocket was dragging on the guide. I fitted a couple of shims to space the sprocket clear of the guide.
ok but is that 15mm with the wheels on the deck or on pit stand?-- I always am unsure!
SAM511
It was the chain being a little loose. It just sounded like the noise was coming from the engine when I was riding. Thanks, I have started using better fuel too.
Thanks for the info boys, doing first enduro of the season The Snowrun on 5th feb. Abbey Enduro 2 weeks later-- looking forward.
