hi guys had my te 449 now 12 months or more,started to get bit of chain noise so checked chain and there seemed to be tight spot then slack spot ect replaced front sprocket and chain (supersprox fitted to rear) to find out not much better if i tension the chain on the stand to 5mm as per husky on tightest spot when i turn wheel to slack spot i have 10-12mm is this normall.i have checked wheel bearings ect even swapped rear sprocket but still the same.my theory is that as 13,14,15-51 ratio dont match you may allways have this happen where as say 13-52 is perfect but this is just a theory.If any one else could check there bikes just to put my mind at rest that would be much appreciated
