TE 310 horn
my_urban_chaos
Has anyone moved the horn from in front of the radiator? I have a 2102 TE310 and the horn just collects debris when I trail ride. Any suggestions on remounting it in another position?
I'm interested as well. Anybody that has done it, if they could post pics it would be appreciated. Thanks.
So what improvements did KTM make to the TE310 in the 22nd Century? :D
On the 2010 TE310 is it mounted behind the headlight mask on the left side, LIKE IT SHOULD BE. Stays out of the way and clean. I don't have any pictures.
On my 07 KTM 525 the horn was mounted to/in front of the radiator, bad place as well, still gets alot of debris and dirt in it and blocks some of the airflow to the radiators.
Guys ,i purchased a smaller horn with a straight bracket on it from a local road bike dealer ,to fit i removed tank ,took out the lower coil mounting screw and replaced it with a 12mm longer one ,then using two nuts on the thread one either of the horn bracket tucked it up tight under the tank/frame the cables just reached its tight on the 310 but it fitted. No pics sorry and have just picked up a 2013 te310r today so will see if it works on that as well if it does will take some and post .
