Te 310 gear lever 2008
zambo
I cannot get my gear lever into the right height postion. When I wear boots it just a little to low. If I raise it one tooth on spline it is to high and hits the front sprocket on up changes.I have a after market gear lever RFX brand.The bike shop tells me that it suits most TE models. I have looked on my mates bikes KTM / Yamaha and the gear levers are also a longer distance from footpeg to gear lever tip.How can I fix this problem?
I went through exactly what you're saying.
What I found to help was buying a +20mm Hammerhead shift tip, like this: http://www.hdmoto.com/Shift_Tip_p/st20w.htm
I believe it was the CRF450 model that worked. It took a little rigging to have it fit, but I had put it on an aftermarket lever. Sorry, can't remember the brand. Not sure if it'd be easier on the stock lever (or the RFX).
I also bought Sidi boots which had a lower toe box than the Alpinestars I was using. This helped as well. I also found them much more comfortable.
Actually, I just found the tip that I removed from the aftermarket shifter, and it is RFX.
Same here , Hammerhead offset shift tip made a world of difference . I am able to fit my toe under it with asize 11 boot with ease . I drilled out the factory rivet
and removed the the sharp inner edge of the Hammerhead tip to prevent cover damage . It's held up to some massive rock riding for two years now .
Thanks for the help I have ordered a new HammerHead tip and I,ll see how it goes. Seems like a problem and most riders just put up with a lever that is too short. Well setup controls make a world of differance to the rideing experiance.
I had an 09 510. Almost impossible to get a size 13 boot under the lever.
Bought the +20mm and it was better. Also added fastway pegs in low position which put the pegs back about 10mm too.
