TE 310 Gas Tank Help
ncgrecon
So I have had these "nuts" come out of my gas tank before. I usually just epoxied them back in. Now I have lost it. Any ideas or a solution or where I can get the brass nut that is manufactured into the tank. Thanks.
If you were thinking of getting a larger tank, sounds like now would be a good idea. Doesn't solve the problem but may be an alternative.
That hole is looking pretty big. Wonder if you could epoxy in a drywall anchor and just use a screw to attach the front of the shroud?
