TE 310 Blinkers
CindyTalk
Hi all, I have just purchased a 2010 model TE 310.
Im trying to refit the (indicators) blinkers.
Couple of questions:
Front and rear come in two wire lengths. Does it matter which goes where, i.e. front shorter wire and rear longer wire?
If this doesn't matter then what should I check to get them to work, so far no flash no nothing.
Is it common on this model for the brake lights, high beam, blinkers, horn not to work unless the engine is running?
Many thanks for the help:notworthy:
I have a 2011 310 & the rear blinkers have the longer wire so the reach the loom under the tail light. As for the lights not working that correct they only work with the engine running. Hope this helps.
Thanks for the info Allan, problem solved the bike was missing a relay switch.:banana:
