te 310 2011
beastione
hello
i am looking to buy a new te 310 2011
i want to know what we have to do with the bike when we buy it ?
thanks
thanks, the skid plate is awesome !!
but , what i want to know is waht you do with the bike when you buy it , brand new .Most of the people tell me than we ha much to do to prepare the bike !
Check every screw, bolt nut, etc. for proper torque (give 'em some locktite if you don't want to replace a lot of them). It's a bit of a hassle but I'd re-grease the suspension and wheel bearings as well (especially the lower rear shock bearing). They seem to be lightly greased for a bike expected to go through every type of abusive terrain imagineable. I bought mine used and within a month replaced the front wheel bearings and every bearing in the suspension. I've had quite a few bolts disappear and several (including engine mount bolts) come loose.
Good dealer will do all that for you and put the power-up kit on. Make sure it's a good dealer who will actually do proper set-up not just say it's good. Otherwise would need to do as posted above, which is true of any bike you buy no matter the brand.
Husky 310 specific stuff is all previously posted if you do a search. Would want to be able to do efi adjustments either by dealer, I-Beat, or JD tuner. Much easier than changing jets once you figure it out. Where and how you ride makes a big difference what you do from there.
