Slowpoke
Last June I severely watered out my 07 TE250 with some pretty nasty chocolate milky mudhole water on a 500 mile ride. The bike had about 336hrs and ~9000 km on it at the time, all original.
(It had been using some oil on long road sections for the last 10-20 hours before that.)
We couldn't get the bike going again & deduced it had no compression. On the tow rope it went back our support truck & that was the end of our ride.
Once home I cleaned out the engine with numerous flushes of oil, WD40, varsol and lots more oil. I also disassembled the carb and airbox & cleaned all the filth from them. I couldn't get it running and made the assumption that either the bore/piston was damaged or one of the valves had dirt stuck under it, or was damaged, as it still had no compression. I assumed it may need a rebuild given the oil usage it had been experiencing before it watered out.
I planned on possibly putting a 310 kit on it, if it needed a new piston or bore, when funds allowed, which at the time it thought would have been last summer.
I finally got around to taking it apart this past weekend(best laid plans......
Once I pulled the head off, there was a fair bit of black carbony fluff on the top of the piston and the combustion chamber. The exhaust ports were coated with thick sticky black oily residue and the exhaust valves had a good layer of carbon burned onto them.
I pulled the jug and piston out and they looked to be in very, very good condition: no scratches or scuffing and just a small dime sized polished wear mark in the center of each piston skirt.
Diagnosis:
All the rings were stuck in their grooves. The oil rings must have become stuck first and allowed the bike to use oil(not sure what would have caused that.......). Then when the bike watered out, the compression ring became stuck, causing the bike to lose compression.
Everything cleaned up nicely. I filled the exhaust ports and then the intake port with varsol and let sit for several minutes each time to see if anything leaked past the valves. Nothing leaked, so the valves are still sealing well.
I freed up the rings using WD40 and patience. I cleaned out the grooves once I was able to remove the rings, although there wasn't much junk in there. There isn't much clearance so it wouldn't take much to jam things up.
I checked end gap of the compression ring in the bore- The manual calls for .008" to .016" gap new, with replacement at .027". Mine with 336hours on measured .014". Not bad!
After everything was cleaned and checked, I reassembled everything along with a new set of gaskets.
I should be able to fire it up this week, once I get the cams back in(another story).
Conclusion:
This bike should get easily 500 hours or more out of the top end without too much trouble and what I thought was going to be an expensive fix turned out to be quite minor.
Diagnosis:
Conclusion:
