So yesterday I bought a 2008 TC450 (Carb, kick start only, Arow titanium exhaust), 17hours since full rebuild (at least that's what the seller said).
Anyway the seller started it on second or third kick, no difficulties (altitude being close to 150meter, with 22Celsius degrees), I made a short test ride to make sure the transmission was well and no defects.
I hit the kill switch and started to kick it again, to see if I could start it, well after 3 kicks I had it running (being new to a 4t kickstart, can kick my WR250 all day long, starts every time).
Now to get to the point, got it home (close to 200meter altitude, 22 degrees Celsius), I cant get it to start, I must have kicked at least 40times, even had some help with it.
Started with the procedure as in the manual, petcock/tap open (screw type, counter clockwise is open), puled cold choke out (black knob), ((made sure red knob/ hotstart was in), twisted throttle two times (ACPump) searched for TDC, pulled the decomp lever, and slightly lower the kickstart/leg (past TDC), then let go of the decomp lever and kicked it.
I've had it running after quite a few attempts, it heated up very quickly, and it didn't run very nice some popping and flames (carburetor lean?), also cut out quite fast, tried it with choke on and of.
Made sure it got fuel, and had a spark.
What will cause this symptoms?
Valve clearance, carburetor jetting, timing, ignition?
Kinda lost in the whole 4stroke happening, I'm quite handy if I say so my self unfortunately don't have much experience when it comes to 4t wrenching, (2t no problem).
